2.7T Startup Question
Old May 7, 2003 | 01:50 AM
Elmo's Avatar
New Member
Default 2.7T Startup Question
When I start my car it revs high in idle (apr. 1200-1400 rpm) for about 30 seconds. During that time when I try to accellerate it moves very slowly and makes a lot of noise. I was driving a 4.2 prior to this car and never experienced anything like this. Is this normal, is it a turbo issue?
Any help would be appreciated.
Old May 7, 2003 | 02:53 AM
saholz's Avatar
Default Re: 2.7T Startup Question
My 2.7 starts easily and drives normally when cold. It seems a little louder when cold, but nothing I would call intrusive. The only thing different when cold is the Tiptronic transmission, which shifts hard until warm.
Stan
Old May 7, 2003 | 03:43 AM
Rick M L's Avatar
New Member
Default Air injection pump...
I had a 2000 2.7 and never had that sound, now have a 2003 and have the same thing, slightly throaty rumble for about 30 seconds on cold startup. I thought I had an exhaust leak, the service manager tells me its an air injection pump to reduce emissions on cold starts. Said it is in changed location from earlier models and the noise is more evident. Sounded reasonable to me. It rumbles for 30 seconds or so and then abruptly stops.
Old May 7, 2003 | 10:07 AM
ar2002's Avatar
Junior Member
Default What you describe (noise, acceleration) doesn't sound normal to me...
Unless, perhaps, this is an older car. Mine is a bit noisier at startup, perhaps, but not much, and drivability is fine. Idle is a bit higher on startup, too, but this is normal and on-par with other vehicles. The TIP is slow to shift when cold, though.
Old May 7, 2003 | 02:12 PM
Elmo's Avatar
New Member
Thanks, I feel better now
Old May 7, 2003 | 06:05 PM
Mike Shields's Avatar
The air pump feeds oxygen to the exhuast to light the CATs
EMJ313
Q5/SQ5 MKI (8R) Discussion
16
Nov 17, 2013 12:20 PM
WylieC
Audi allroad
Oct 5, 2007 01:07 AM
hellboy
25
Apr 5, 2006 06:20 PM
DaveyKid
11
Dec 28, 2003 06:42 AM
HaftaHaveA4
Mar 1, 2001 08:36 PM
