Throttle adaptation RESET on A6
Old May 7, 2003 | 06:31 PM
Jojo 3's Avatar
New Member
Default Throttle adaptation RESET on A6
Does N 1 know if you can reset the throttle response on A6Qt '99 - (as the car is coming from the factory not adapted yet to your driving style )....?
-I did tried on my A6 ("the 10 sec. trick ") , but no difference .
PS: I know that trick work on my '01 bimmer as :
either disconect the battery for some time or :
2 --- turning the key till all lights on the dash board do light up than count up to 10 sec., then remove key count 10 sec. again, than insert the key and start the car as normal >>> and by that the throttle is reset ...
Btw on E46 but 328/323 the one before '00 it is more involving as you have to pump the gas pedal and so on .... don't know if that is the case with the A6 from '99 too ?
Old May 7, 2003 | 06:56 PM
DUBITUP's Avatar
Turn the key to on position and press gas pedal to floor 5sec should do it.
Old May 7, 2003 | 07:01 PM
Ming 2.7T's Avatar
Craggy Old Man
25 Year Member
Default Is that for the tranny reset? Thought throttle adapt was turn key to on and leave it for a bit??
Course I may be wrong as usual, I am old and tend to mix things up.
Old May 7, 2003 | 07:52 PM
Jojo 3's Avatar
New Member
THX for the tip =) , ( will give a try )!
Old May 8, 2003 | 04:58 AM
DUBITUP's Avatar
I did not know about that one, I'll that also, thanks
Old May 8, 2003 | 07:25 AM
TXurS6's Avatar
Default Reportedly the "bit" is something like 2 or 3 minutes...
anecdotal as I've tried it and didn't notice any significant change.
triplecore
Jun 15, 2009 07:14 PM
frybear
Nov 28, 2008 08:31 AM
Maui19
Dec 16, 2004 07:34 AM
OPTIMUS PRlME
Dec 26, 2003 12:37 PM
jw_dimock@yahoo.com
Jan 31, 2003 10:11 AM
