Reset computer by unplugging battery?
Old May 23, 2003 | 05:42 PM
MNDriver's Avatar
Default Reset computer by unplugging battery?
Is it possible to reset all the modules in the a6 back to their "defaults" by disconnecting the battery? If so, how long does it need to stay disconnected?
My "new" car has been tweaked a little bit by the previous owner, I just want to go back and get everything back to stock.
Old May 23, 2003 | 06:00 PM
Haystack's Avatar
Default You will need a VAG COM to reset everything
About the only thing that you can "reset" by disconnecting the power is the throttle body adaptation.
After disconnecting and reconnecting power to the ECU, leave the key in the "run" position for a few minutes without starting the car or touching the accelerator pedal.
Everyhthing else that I know of is saved in non volatile memory in the ECU and has to be explicitly set/reset.
Check the VAG COM pages here for more info. Also, check<ul><li><a href="http://www.ross-tech.com">http://www.ross-tech.com</a</li></ul>
Old May 25, 2003 | 07:05 AM
GIACUser's Avatar
Junior Member
Default Have a member help you.. many VAG owners willing to help, go to this site...
http://www.steve-hall.com/cgi-bin/VAG-Locator.pl
perhaps you can find someone in your area.
Sfoe
Mar 29, 2006 07:56 PM
Mass B5S4
Feb 15, 2006 04:24 AM
nyc_qcar
Jul 8, 2004 02:48 PM
kshawn126
Dec 12, 2003 05:09 AM
Dirty Dingo
May 15, 2002 06:57 PM
