Braking from high speed, front-end wiggle in steering wheel?
Old May 23, 2003 | 06:49 PM
NexxTT's Avatar
Senior Member
Default Braking from high speed, front-end wiggle in steering wheel?
Irritating because it's not rock solid, but not really that bad.
About 12,000 miles ago, dealer replaced the front rotors which we/they thought might be causing a shimmy/wiggle on high speed (95/90mph) braking on the A6/2.7TQMS. They did not replace pads as far as I could tell from work order.
Recent new tires on car (same Dunlop SP9000s) with good balancing for about 1,500 miles and have noticed the same shimmy/wiggle on high speed braking.
Anyone suffered same problem - solution?
Is it possible rears are warped too....as the shimmy never went away totally even after rotors replaced?
Car is stable at high speed travel with minute shimmy at between 70-80mph felt in steering wheel only. Disappears 85-100.
Old May 23, 2003 | 07:01 PM
mbr's Avatar
mbr
Sounds like warped rotors, I would have dealer replace rotors again, and pads.
Old May 24, 2003 | 04:48 PM
Tiptroniq's Avatar
New Member
Default Re: Braking from high speed, front-end wiggle in steering wheel?
I had the same issue in my S6 and the dealer replaced the rotors and pads. No problem with braking anymore, but now I think the gas peddle vibrates at high speeds, not sure if it's the car or the award-winning Massachusetts highways. We won the award for the worst roads in the country.
RydeOdie
11
Aug 10, 2012 08:37 PM
GDawgA4
May 19, 2006 12:06 PM
GDawgA4
13
May 9, 2006 09:35 AM
Boulder Allroad
Audi allroad
13
Feb 11, 2006 01:09 PM
audiphobic
Aug 24, 2005 05:11 PM
