Valentine 1 Mounting Saga Continues
Old May 24, 2003 | 07:40 AM
dlubin's Avatar
New Member
Default Valentine 1 Mounting Saga Continues
Thought someone might get a kick out of this...
Since I was determined to find a 12v switched wire in the sunroof area (to avoid running from the fusebox or the homelink visor) I tested out every wire I could find and ...
Pin #2 on the Sunroof Connector lit up with 12v with the key in, 0 once the door was opened!
So, thinking I was 'all set' I wired everything up, turned on the V1, and
The sunroof closed.
#$%$#@$#@R
Old May 24, 2003 | 07:43 AM
2.7tDallas's Avatar
AudiWorld Expert
Default BWWAAAA - just do a wire tuck like I did, with a hrad wire to the fuse box
I will go shoot a picture right now
Old May 24, 2003 | 07:54 AM
2.7tDallas's Avatar
AudiWorld Expert
Default Re: BWWAAAA - just do a wire tuck like I did, with a hrad wire to the fuse box
<center><img src="http://pictureposter.audiworld.com/5503/img_0015.jpg"></center><p>Here is a pic. Use fuse #27, as it is switched. use the standard flat V1 cord, and tuck it down the headliner and A-pillar.
use the 2 into one fuse holder like this one to get a hot wire. I got mine at pepboys. there are a couple of 8mm bolts near the fuse panel that are good grounds
Old May 24, 2003 | 03:23 PM
dlubin's Avatar
New Member
Default Done! (m)
I finally gave in and wired it as you suggested &lt;g&gt;. Only difference is, I just plugged the spade connector into the fuse area vs. buying the dual-adapter. I had to strip the plastic housing away from the connector, but it fits just fine. I used the following as a guide:
http://php.indiana.edu/~chihuang/vw/radar/v1.htm
The wire is very well hidden except for two areas along the a-pillar where I can't get the wire to tuck all the way behind the trim panel - any suggestions?
-Dan
Old May 24, 2003 | 03:41 PM
2.7tDallas's Avatar
AudiWorld Expert
I sed a fat screwdriver to tuck it in tight - but it still shows a little
Old May 24, 2003 | 06:04 PM
Jon C's Avatar
Elder Member
Default a credit card works well, right thickness & won't cut into headliner, etc.
That pushed the wire in mine so that none is visible.
Old May 25, 2003 | 07:55 AM
PaulW's Avatar
Default Use a plastic paint scraper from Home Depot
<center><img src="http://www.audipages.com/upgrades/v6030.JPG"></center><p>Found in the paint department. About $1
Old May 25, 2003 | 10:13 AM
dlubin's Avatar
New Member
Default I wonder if I went the wrong way..
I went across the headliner, down the A pillar between the trim and the windshield, behind the dash, and into the fusebox.
Was there another alternative?
-Dan
 Pouria Savadkouei
 Michael S. Palmer
q5q7
A6 (C7 Platform) Discussion
10
Mar 30, 2014 11:46 AM
hoosierchemist
16
Jul 31, 2008 04:49 PM
BillK
Mar 24, 2002 03:50 PM
IPsychL2
Mar 4, 2002 06:41 AM
