How important is a 5-bar fuel pressure regulator...
Old May 25, 2003 | 10:30 AM
BlackA6's Avatar
New Member
Default How important is a 5-bar fuel pressure regulator...
in a car that is "only" chipped (no K04's)? What are the benfits? I noticed that OCT includes it already in their stage 3... Thanks!
Old May 25, 2003 | 02:05 PM
urq20vt's Avatar
Default It enables the injectors to flow more fuel without increasing the injector size.
This enables the injectors to operate in their optimal duty cycle range (generally < 85% or so) or less. More fuel available = more power available.
The ECU MUST be programmed with the appropriate injector timing to go along with the increased fuel pressure. Generally, this is done to save you the expense of replacing all of the injectors.
With most K04 kits you receive RS4 injectors with adapters (the RS4 injectors are physically smaller) or equivilent flow injectors of the same physical size as the original injectors.
HTH!
SilverA4Fun
Mar 23, 2007 06:05 AM
~DonQPremiumTequila~
Apr 29, 2006 04:11 AM
bl97
Mar 13, 2003 05:14 AM
Mike O.
Performance and Tuning
Mar 26, 2001 09:48 AM
joemamma
Jul 2, 1999 06:21 AM
