A-6 speedometer/speed sensor problem
Old Dec 7, 2004 | 11:25 AM
docrob's Avatar
New Member
Default A-6 speedometer/speed sensor problem
Intermittanly for several months, the speedometer on my '98 A-6 worked erratically and at times not at all. The odometer wouldn't work either. I had a bad tie-endrod that was replaced. Eventually, after running codes and not seeing anything else, the speed sensor was replaced. Everything worked well for a week, then it stopped, only to resume working a week later for no apparant reason. Another shop was doing some work on a few of the many re-call items this car has had, and found a cracked CV boot on the left front wheel. They hypothesized that grease was intermittently being thrown, and obstructing whatever is the speed sensor pickup. The first shop says this is bunk and that the speed sensor for the speedometer is enclosed in the transmission. Anybody have any thoughts on this. As you might tell I'm not that knowledgeable on these issues. thanks
Old Dec 7, 2004 | 12:31 PM
6ULDV8's Avatar
Junior Member
Default When your speedo is out, does your odometer quit working to?
If they quit working together than you have a sensor or wiring problem. If the odometer works when the speedometer is not then you have an instrument problem.
Old Dec 7, 2004 | 01:33 PM
docrob's Avatar
New Member
Default Re: When your speedo is out, does your odometer quit working to?
Yes, but the the rest of the display works fine. Someone thought it was a display issue, but that doesn't seem at all likely. When the speedometer is flat line, it won't work in reverse - I usually don't go fast in reverse, but it does register something about 5 mph. It also seems as though the low speed turning is more difficult also.
Jose Arriaga Jr.
Nov 14, 2017 11:37 AM
msd29
Oct 15, 2010 04:39 PM
gamecock
Jan 10, 2008 09:32 AM
victor army
Apr 8, 2007 08:54 PM
rockfanatic
Telematics Discussion
Feb 21, 2006 01:09 PM
