Cold Air Intake...
Old Dec 9, 2004 | 01:02 PM
John/Jmess5's Avatar
Member
Default Cold Air Intake...
<ul><li><a href="https://forums.audiworld.com/newengland/msgs/7155.phtml">https://forums.audiworld.com/newengland/msgs/7155.phtml</a</li></ul>
Old Dec 9, 2004 | 01:07 PM
Potomac-Greg's Avatar
Default The airboxes in our cars (esp. turbos) are pretty well designed. Putting a filter in...
... an open area of the engine bay may actually reduce airflow, and will suck in hot, engine-bay air rather than outside air. If you look at the intake snorkle, there are probably things you could do to get more airflow into the airbox.
Old Dec 9, 2004 | 02:34 PM
a_o_smith's Avatar
i dont know about the 2.7 but the 2.8's airbox has 2 90 deg turns, and 1 180 deg...and i tiny scoop
Old Dec 9, 2004 | 08:46 PM
April's Avatar
AudiWorld Uber User
The twists and turns aren't good, but a long intake tube means more low end torque.
Old Dec 9, 2004 | 09:12 PM
a_o_smith's Avatar
i knew that...even thought i never understood why...but the small scoop is crap...
Old Dec 10, 2004 | 07:01 AM
jasaab's Avatar
Member
Default Yes EVOS
I picked one up on ebay for under a $100.00. Alot of the S4 guys use this one. It has a great insulated panel. It makes some cools sounds on acceleration but as for increased performance, I doubt. Looks the filter element would take alot of beating for the elements. I just drive my AUDI in the fair weather.
Old Dec 10, 2004 | 10:06 AM
Could you retro-fit a 2.7T scoop??
Old Dec 10, 2004 | 10:20 AM
April's Avatar
AudiWorld Uber User
Default Long intake increases air velocity, but does not have the capacity at higher engine pumping speeds.
Hence cars with variable length runners.
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 10, 2004 | 10:46 AM
a_o_smith's Avatar
they have them...i think theyre built into the grill but im sure could could if not
KNaudiA4
Apr 20, 2003 09:21 PM
silver rain
Jan 20, 2003 02:25 AM
ABT SUN
Dec 17, 2002 12:33 PM
Prok
Jun 12, 2002 04:21 AM
Edward A
Apr 11, 2000 07:06 AM
