Replacement Xenon Headlight Bulbs
Old Dec 9, 2004 | 06:41 PM
bear1906's Avatar
Default Replacement Xenon Headlight Bulbs
OK...I see some of the old posts on this topic...But I cannot live with the new xenon headlight that the dealer installed on my 99a6 2.8 when they replaced my defective one...Its to white/yellow and doesn't match the other side...I don't even want to get them to replace the other one because I hate the new replacements' color...So I am going to replace the xenon bulbs in my existing housing...I want really bluish ones that are good quality too...any recommendations?
PS- How hard are they to change? Any FAQs on this?
Old Dec 9, 2004 | 06:51 PM
Max_A6's Avatar
Junior Member
ebay? Replacement is easy.
Old Dec 9, 2004 | 06:58 PM
bear1906's Avatar
Default Re: ebay? Replacement is easy.
OK Max_A6 can you elaborate?
What do you think about the 8000k or 10000K on this site?
http://www.hidexpress.com/index.asp?PageAction=VIEWPROD&ProdID=15#
Old Dec 9, 2004 | 07:02 PM
Max_A6's Avatar
Junior Member
Default Rice!
Seriously, they put 4300K for many reasons. Get OEM Philips D2S for $80/pair.
Old Dec 9, 2004 | 07:03 PM
Boston Driver's Avatar
AudiWorld Expert
Default Here is a post I found on how to replace...
Found it searching the A6/S6 forum for "xenon bulb replacement." Don't think I saw this one on Stoney's Links...odd lots of stuff on removing the lens, doing clear corners, setting the leveling with the VAG, I did not see on for the replacement steps.
Anyway, here you go. Good luck!<ul><li><a href="https://forums.audiworld.com/a6/msgs/247513.phtml">Xenon bulb replacement</a></li></ul>
Old Dec 9, 2004 | 07:13 PM
Max_A6's Avatar
Junior Member
Default May need to remove few things for easier access
Plastic cover of power steering reservoir - driver's side, air intake - for pass. side. Installing buls is a bit tricky - there's a gap on the bulb's housing for proper positioning. Be carefull not to drop pins that hold the headlamp covers, otherwise you'll have to search for it somewhere in the belly pan.
Old Dec 10, 2004 | 03:11 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default Second.
The further you stray from the 4300 heat range, the narrower the spectrum of light you get. The whole purpose of xenons is for better lighting. Why dumb it down?
Old Dec 10, 2004 | 03:37 AM
bear1906's Avatar
Default Re: Second.
So if I want something a little bit bluer than the OEM, and much bluer than the crap they are replacing the HID headlights with, what should I chose?
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 10, 2004 | 07:00 AM
Max_A6's Avatar
Junior Member
A bit bluer = 6000K. A lot bluer = 8000K and up.
Old Dec 10, 2004 | 09:25 AM
SloopJohnB@mac.com's Avatar
Tech Guru
Tech Guru
Default There are different p/n for D2S bulbs...
Some M3's come with a p/n different from the Audi bulb even though they're both D2S bulbs. The BMW part is $230 list vs the Audi $180 list (Ask me how I know this). The M3 bulb is whiter than a 5 year old 4.2A6 D2S..........
Somewhere I read that the stock bulbs are like 4K Kelvin vs 5.3K K which would support my observation that the M3 bulbs are 'whiter.'
I haven't plugged in the replacement bulbs, just noticed the p/n changes.
hosickjg
Nov 27, 2010 08:49 PM
Hibiscus Red S4
May 4, 2006 10:52 AM
El_Zorro
May 5, 2002 02:26 PM
mudd
Mar 21, 2001 09:24 AM
DWC_2.7T
9
Oct 9, 2000 04:12 AM
