Xenon headlight flickering
Old 11-21-2010, 11:35 AM
hosickjg's Avatar
Default Xenon headlight flickering
The passenger side Xenon headlight started flickering on my A4. If I had to guess I would say the ballast..... any other suggestions?
Old 11-21-2010, 02:15 PM
mullardel34's Avatar
Try swapping the bulb or the ballast from one side to the other and see if the flickering follows a component from side-to-side.
Old 11-27-2010, 08:12 PM
s4master1's Avatar
Default flickering
if you have the d1s bulbs replace the bulb, you can tell by the square unit attached behind very common problem we stock 20 at all times because of this
or swap them side to side to make sure
Old 11-27-2010, 08:49 PM
nexusgroove's Avatar
trouble shoot it with the swap method said above.
most cases, the flicker is the bulb going. from my experience
DDM tuning has some great replacements. A bad ballast would be no strike of the lamp. IMO
jmac172
02-20-2012 05:38 PM
Hank
11-07-2009 10:00 AM
nogaro*blue*you*away
01-14-2009 06:27 PM
BlakeBoston_06
A4 (B7 Platform) Discussion
12-31-2008 11:18 AM
CEEZZ
09-15-2003 09:46 PM
Quick Reply: Xenon headlight flickering
