Oil filter....pour oil in it when installing or not?
Old Dec 11, 2004 | 08:19 AM
TalonLM's Avatar
New Member
Default Oil filter....pour oil in it when installing or not?
Again...sry for the newbism. Looking at the bently manual it shows the oil filter parallel to the ground. Other cars I've owned they have been tilted up, so when you fill the filter full of oil when installing it it doesn't spill...much. Does it really matter if you fill it? I know you wet the gasket to make a good seal, but is it critical to fill the filter when replacing? Thanks.
Old Dec 11, 2004 | 08:22 AM
6ULDV8's Avatar
Junior Member
No need to fill the filter.
Old Dec 11, 2004 | 08:28 AM
TalonLM's Avatar
New Member
Default So I'm guessing when you pour the oil in the engine it will find its way there anyway? I wonder why
people have always told me to fill it? Thanks!
Old Dec 11, 2004 | 08:37 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default Not exactly.
The filter isn't filled until the engine is started and the oil pump fills it.
The reason for pre-filling the filter is to limit the amount of time that the engine runs with no oil pressure. I see the reasoning behind pre-filling the filter, but potential damage to the engine for the few seconds it runs without pressure is so negligable that it is not worth the effort.
I don't bother.
Old Dec 11, 2004 | 09:08 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
I always prefull the filters, just out of habit.
Old Dec 11, 2004 | 09:24 AM
SloopJohnB@Home's Avatar
New Member
Default Use synthetic and you're even better off.
Synthetic saved me at least one engine when I hit a cement block or a big friendly rock on the beltway at 530 in the am and ripped out the oil pan, destroyed the oil pump, bent the transmission crossmember, and holed the transmission pan.
Pity the poor sods on the 'way behind me.
As I'm sitting on the side of the road waiting for the flatbed (never never never tow some cars!) I'm watching about three other cars hit the same flinking object. A big tractor trailer finally knocked it off the road but took out his left front tire. Stopped him too.
Lady in front of me with a newer VW bug wasn't so lucky....just kept going without shutting her engine off and seized the engine about 1/2 mile ahead of me.
Old Dec 11, 2004 | 09:28 AM
6ULDV8's Avatar
Junior Member
Default Just to add, that even if somebody was so inclined to
fill the filter first they could never get the filter screwed on before all the oil ran out of it. They would just end up with a mess and wasted oil.
Old Dec 11, 2004 | 09:44 AM
Head Cat Herder
25 Year Member
Default Not hardly. If you fill it, let it soak in a little, fill it so it's about 3/4 full..
I only lose a tiny amount when I screw it on.. Not like it's upside down or anything.. On the 4 cylinder cars, it's even easier.
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 11, 2004 | 12:50 PM
JimR's Avatar
AudiWorld Uber User
25 Year Member
Default Yeah, I wet the media, but don't have a lot of excess beyond that.
It's easy to do, seems sensible.
Old Dec 11, 2004 | 01:29 PM
eric strauss's Avatar
Default A little bit like wearing belts & suspenders :-)
The notion of doing a pre-fill with the oil filter is a strategy to reduce the amount of time that the motor goes without full lubrication pressure. This strategy is very sensible on fresh engine rebuilds that are essentially dry parts - although any rebuilds that I do, I also use assembly lubricant that solves that problem.
When you are doing an oil change, typically you are draining a warm engine, performing the change and then starting back up in a half-hour. Oil film is still clinging to the valve train/main bearings, etc. and their is low/no risk to the parts as the pressure builds (IMHO). If you can avoid spilling the oil on yourself - there is no harm in doing so - the oil pressure needle responds a second or two sooner...
Peace,
eric
baubaulu
A4 (B9 Platform) Discussion
Mar 11, 2017 03:46 AM
draganka
Q7 MK 1 Discussion
May 9, 2014 05:46 AM
MRSK
Nov 10, 2006 01:52 PM
[tri]liament
Jul 24, 2003 11:44 AM
djordan
May 6, 2002 05:10 PM
