Fuse box question: switched and unswitched?
Old Sep 16, 2005 | 09:30 AM
rwish's Avatar
Default Fuse box question: switched and unswitched?
I recently added some audio equipment and tapped into the fuse box for power (using Littlefuse Add-A-Circuit). I'd like all the devices (4 in all) to be connected to switched power. To make it more interesting the 4 devices need to be somewhat spaced out because one add-a-circuit device when used covers the fuses above and below.
Does anyone have documentation on which are switched and which are unswitched? All the manual shows is the fuse # and what it's used for. Most I can guess on (i.e. I know the heated steering wheel is switched) but others I'm unsure of. I'd rather not plug into all 44 and find out by trial and error.
Thanks for helping!
Old Sep 16, 2005 | 09:44 AM
Egil A64.2s - S6's Avatar
Default Probably your best bet would be the cigarett lighter
It should have sufficeint amperage for your needs
Old Sep 16, 2005 | 09:56 AM
NSX JR's Avatar
Default Forget the fusebox... use the power taps under your dash...
<center><img src="http://pictureposter.audiworld.com/59076/fusebox20wiring.jpg"></center><p>the yellow "75X" is what you want. Just be sure to have the proper fuses in line to your equipment, which you probably already have.
Picture credit: TeddyBGame
Old Sep 16, 2005 | 09:41 PM
Default Re: Forget the fusebox... use the power taps under your dash...
Even better but be careful to disconnect the power from the battery before you remove these cables as a short would not be a pretty picture!
Also have your radio codes handy ;-)
q5q7
A6 (C7 Platform) Discussion
Apr 23, 2014 07:53 PM
goldsmjr
Audi allroad
Dec 22, 2007 08:20 AM
2blueturbos
Audi 100 / A6 (C4 Platform)
Jul 19, 2004 03:15 AM
A4ORCE1
Oct 21, 2002 04:46 PM
realdeal
Feb 5, 2001 01:53 PM
