How to select a brake pad and where? 01 A6 2.7T Quattro
Old Apr 24, 2006 | 09:48 AM
ChargingA6's Avatar
New Member
Default How to select a brake pad and where? 01 A6 2.7T Quattro
I have a 01 2.7T and am in need of new brake pads front and back and rotors front and back.
Which brand should I look for and which site is the best to buy them from. TIA
Old Apr 24, 2006 | 10:03 AM
iProDrive's Avatar
Default I am looking for the same thing....
I have a 2000 Audi A6 2.8Q. My front right brake pad is starting to squeak every now and then. I think the previous owner did not put the sensor brake pads on because there is not a warning on the dash LCD.
I was looking at front and rear BREMBO drilled and slotted rotors. I figured since I was going to replace the rotors might as well get some nice ones that will "displace the heat faster". Basically I just want to be able to stop and the stock rotors and pads do that really well so I can only imagine what will happen after the "aftermarket" ones.
For brake pads, I have yet to decide yet...
I did notice that there are two different sensors available for the brake pads. A square or a circle, I am going to pull a wheel off and actually take a look as to what I have. I would like a long lasting high performance brake pad, so if you get some before me let me know as to what ones you are getting and how they are.
Also I was going to replace the brake fluid, I do not know when the last time it was replaced and it needs to be done every two years regardless of the usage, (due to moisture).
Old Apr 24, 2006 | 10:33 AM
MikekiM@PureMS's Avatar
Former Vendor
Default Lots to consider with pads
Some pads are lower dusting, some have better grip, while others can withstand higher operating temps.
Pads should be matched carefully with your particular application to make sure you get the best braking possible.
OE pads are good street pads. They provide good bite for around town, and certainly will stop well in a panic stop. They however don't tolerate elevated temps well, like you'd see on a track. They are also very heavy dusting.
Find pads that suite what you're looking for with respect to:
noise, dust, bite, temps, rotor wear, pad wear, and cost.
Rank those which are most important to you and find some vendors who have something that fit what you're looking for.
OEM pads come from ATE, Pagid, Textar, and Jurid.
Aftermarket pads like Mintex, PBR, Axxis, Carbotech, Pagid, and Ferodo are just a few to consider.
Hope that helps!
Old Apr 24, 2006 | 10:45 AM
no.radar's Avatar
AudiWorld Expert
Default Good online site--->
No shipping charges; no tax.
I've purchased Brembo rotors and S4 brake pads with no issues at all.<ul><li><a href="http://www.autopartswarehouse.com/">I have no connection to these guys.</a></li></ul>
Old Apr 24, 2006 | 01:55 PM
myfirstimport's Avatar
Default I got 80k from my stock pads.....i went with stock again since I dont track the car
<center><img src="http://pictureposter.audiworld.com/15643/misc_002.jpg"></center><p>
Old Apr 24, 2006 | 05:52 PM
KFJ_S4's Avatar
New Member
Default I put on Hawk HPS
Which I got from TireRack. The Hawk HPS is a "performance" street pad. I liked it because it was low dust. I did use them at the track and have since purchased a set of Hawk Blues for my next track outing.
As others have stated, depends on what you want. Track/no-track, low-dust, low cost, etc. Give us some specifics and priorities and you'll have lots of recommendations.
Old Apr 25, 2006 | 10:01 AM
iProDrive's Avatar
NO Track / LOW dust / decent price range / street-highway driving / any suggestions?
Old Apr 25, 2006 | 06:55 PM
KFJ_S4's Avatar
New Member
Default The Hawk HPS
Has impressed me with its low dust, good bite and no squeal. They are a little more expensive than some others, but all I read on them convinced me these were the best bet. This has proven true.
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 26, 2006 | 08:40 AM
iProDrive's Avatar
Think I will give them a chance, thanks for the advice!
ChesterCopperpot1
A6 (C7 Platform) Discussion
11
Jun 3, 2019 06:48 AM
saifxnyc
23
Jul 5, 2015 10:03 AM
SGMJohn
Brakes Discussion
Feb 3, 2015 01:06 PM
Muzique
Jul 3, 2011 04:17 AM
aklasu
Sep 20, 2004 12:01 PM
