OOH NOO!!! I JUST BROKE A BOLT
Old Apr 24, 2006 | 06:17 PM
nasdaqer's Avatar
New Member
Default OOH NOO!!! I JUST BROKE A BOLT
I just broke the fourth bolt that attaches the cam chain tensioner - the one lone bolt by the spark plug. I torqued all the other bolts to 7 ft pounds and this one snapped down in there.
Is it going to be OK to drive,, and just the kind of thing I can worry about until the next cam seal replacement, or does this need to be taken care of asap?
I'm just going to sit in the garage with the car running now...
Old Apr 24, 2006 | 06:31 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Default Take it apart and extract the broken piece.
Are you sure you're torquing to 7?
Old Apr 24, 2006 | 06:41 PM
nasdaqer's Avatar
New Member
Default my torque wrench didn't seem to be calibrated correctly at first
so that one was over-tightened, I'm sure. What do you suggest? Now that I have done this to myself do I have to pull out the cams, etc.?
Or do you think I could use an extractor to try to get it out?
thanks
Old Apr 24, 2006 | 06:42 PM
nasdaqer's Avatar
New Member
Default also - anyone have a part number and / or specs for those bolts?
looks like I'll need to order another one. I hate my life.
4Driver4's Avatar
Tech Guru
Tech Guru
Depends on how it is broken. It won't be easy to avoid pulling the cams.
Old Apr 24, 2006 | 06:46 PM
4Driver4's Avatar
Tech Guru
Tech Guru
I'd go dealer only on that.
PartyBoyRacing
16
Dec 26, 2008 08:48 PM
orangedawg
Jul 18, 2008 10:30 AM
Catamount90
12v V6 Discussion
May 7, 2007 06:44 AM
squirrelly333
Audi 100 / A6 (C4 Platform)
Aug 28, 2006 12:34 PM
S4KTS
Feb 6, 2006 06:11 AM
