Need help finding a gremlin. I have a creaking noise coming from my B pillar
Old Apr 26, 2006 | 06:29 PM
yrk2.7t@curbside's Avatar
Default Need help finding a gremlin. I have a creaking noise coming from my B pillar
seems to be right around the seatbelt adjuster, but I can't seem to narrow it down. If I get on and off of the gas I can duplicate the noise.
Old Apr 26, 2006 | 07:13 PM
Boston Driver's Avatar
AudiWorld Expert
Default Do you have the OEM phone setup in the car (little square speaker below the seatbelt adjuster)...
I have heard a few things about the RS6 models having issues with static coming from the speaker, and varies with speed.
Other than that, the only thing I can think of is the seatbelt adjuster itself. Have you tried moving it to a higher/lower position to see if it still makes the creak?
Maybe some lube for the gaskets around the doors might help as well.
Hope you find it...nothing more annoying than a mystery noise...
Old Apr 26, 2006 | 07:16 PM
Default Nope, no OEM phone. I did try moving the seatbelt around didn't make a difference,
If I am cruising at say 40 MPH and let off of the gas it will creak. If I get back on and then back off of the gas it'll creak again.
I thought I read something on AW about the Exterior black B-Pillar cover making this noise, but I couldn't find anything on the search.
I may just end up taking off the interior panel and seeing if I can isolate it.
Old Apr 26, 2006 | 07:21 PM
AudiWorld Expert
Maybe try to treat the door gasket near the B-pillar?
Old Apr 26, 2006 | 07:26 PM
Default Yea that's not a bad idea. When I have time i'm going to dig into it more. Just wanted to see
if I was the lucky one, or if someone else had something similar :-D
Thanks Henry!!
Old Apr 26, 2006 | 08:41 PM
Stoney's Avatar
Tech Guru
Default Rear door seals and sunroof are the worst offenders....
See the FAQ section on "noises".
Old Apr 27, 2006 | 02:13 AM
bac2h's Avatar
Ace Ventura
Default I chased the same creaking noise for a year!!!! Mine was not in the B Pillar but
the latch assembly in the door which bolts to the door. There are two large black bolts on the endge of the door, I think they are a number 8 hex bit that hold the latch assembly to the door. Try loosening them a bit. I had to actually put some of the fuzzy side of velcro down where the plastic latch assembly meets the door to act as a buffer between the plastic housing creaking against the metal. Hard to explain. I can snap some pics if need be.
Bill Bachhuber
New Hartford, CT
Old Apr 27, 2006 | 08:42 AM
Some pictures would be awesome!! I was jhoping someone else had this :-)
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 27, 2006 | 08:43 AM
Hmm Thanks Stoney I'll re-read that. Could be the rear door seals.
mausland
Jan 25, 2013 07:36 AM
fignewton
Jan 5, 2006 08:05 AM
Metronet
May 23, 2003 12:12 PM
Trent
Jan 10, 2003 06:11 PM
Dan Wyman
Dec 11, 2002 10:25 AM
