Clear corner problem, i don't think its possible with a dremel??
Old Aug 3, 2002 | 09:01 AM
SameerP's Avatar
Default Clear corner problem, i don't think its possible with a dremel??
Well drilled the holes, and noted the instructions say to eat away at the tabs. The problem is that the one tab is, distance wise, too far away from the lower hole i drilled, my dremel drill bit won't reach. I ran to Home Despot (i mean Depo) and Dremel does not make an extended reach drill bit. So then i checked out all the other maker bits (Bosch, etc) and there isn't any drill bit that length...makes sense as the bit would likely break...
What am i missing? People that used traditional drills could have of course used long drill bits...but i don't have access to a traditional drill here.
Cheers,
Sameer
Old Aug 3, 2002 | 09:15 AM
coocoomike's Avatar
Default i did it with a dremel, pull out the drill a lil and retighten? also try breaking off the tabs
instead, went A LOT faster for me. use like a small screwdriver or something.
Old Aug 3, 2002 | 09:37 AM
SameerP's Avatar
Default duh, that makes sense...
glad i stopped to pick up compressed air and silicone.
Ill give it a try.
Cheers
nogarobluedemon
15
Aug 21, 2007 09:21 PM
a_o_smith
10
Jul 4, 2005 09:24 PM
Rawfonics
Aug 26, 2003 11:09 AM
kevpm
Jan 4, 2001 07:01 PM
