Timing belt question
Old Aug 3, 2002 | 08:14 PM
tmmatthews's Avatar
Default Timing belt question
I'm in the midst of changing my timing belt (and snub mount, and BPV) and I've run across a potential problem. I marked by belt and position of the cam and crank sprockets. The new belt is on and all the the marks I made line up but with the cam sprocket aligned, the crank sprocket is off of the factory marks (on the damper pulley and lower timing belt cover) ~2-3 teeth counterclockwise.
Here's the question: do I go with what the car was running prior to replacing the belt or do I go with the factory alignment? The car was running fine prior to the tb change, although a bit sluggish even with an APR chip. I'm leanig toward going with the factory marks, since the car was in an accident some time ago and I have no idea whether the 'tards at the body shop (that's a story in itself!) messed with the timing belt or not. The Bentley manual says simply to line up the cam/valve cover marks and the damper pulley/tb cover marks.
Thanks,
Old Aug 3, 2002 | 09:44 PM
kingfishgrapejam's Avatar
Could you have accidentally moved the crank while loosening the pully bolts??
Old Aug 4, 2002 | 05:50 AM
tmmatthews's Avatar
Default No. The old tb was installed when I took off the damper pulley (m)
The marks I made still correspond to where they were with the old tb installed.
Old Aug 4, 2002 | 03:50 PM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Line it up according to the marks on the pulley.. It was probably off..
fshik
Jul 4, 2008 09:48 AM
Dr. Jitter
Oct 4, 2005 10:31 AM
Jeff Doble
14
Aug 7, 2005 07:23 AM
Hidshadows
Aug 11, 2003 12:53 AM
TimTwigg
Sep 5, 2002 07:19 PM
