Uh oh....what's this engine code mean?
Old Jul 20, 2007 | 08:59 PM
ePuFFy's Avatar
Default Uh oh....what's this engine code mean?
Just got my camshaft tensioner replaced, and also timing belt service... was driving home and this thing came up on the display. I restarted the car a few times, and everytime I put it in drive the 1st time after starting the car beeps and shows this, and it stays on the display....
<img src="http://i3.photobucket.com/albums/y80/logigeek/IMG00060.jpg">
Old Jul 20, 2007 | 09:33 PM
ndjano's Avatar
Default something is wrong with the headlight auto-leveling system...
did you recently lower the car?
Old Jul 20, 2007 | 09:50 PM
ePuFFy's Avatar
Default Yeah, I also did Eibach springs and Koni shocks....
what do I do to fix this?
Old Jul 20, 2007 | 09:58 PM
kingfishgrapejam's Avatar
Default Make sure your sensors are hooked up and clear the module with Vag
It may have just threw the code while you were messing around with the suspension. My body shop did that and I just had to clear it from the headlight auto leveling module and it stayed away.
Old Jul 20, 2007 | 10:02 PM
ePuFFy's Avatar
Default ahhh... got it. I'll check it with my VAG tomorrow... so >>>>
I need to go into the headlight module and clear any codes in there? I've never messed with the individual modules, just the general fault codes part....
Or do I need to recalibrate my headlights somehow?
Old Jul 21, 2007 | 06:40 PM
EdCz's Avatar
New Member
Default Re: From Stoney's links...
https://forums.audiworld.com/vag/msgs/501.phtml
Old Jul 21, 2007 | 09:17 PM
Default Can't remember the exact module name might be xenon range. I know I just poked around a little and
It made sense at the time. I didn't recalibrate anything once the code cleared they started working correctly again.
Old Jul 22, 2007 | 12:16 PM
ePuFFy's Avatar
Default I cleared the fault codes, and the error still comes back... what>>>
do I need to change some of the values in the headlight module in VAG?
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 22, 2007 | 12:41 PM
ePuFFy's Avatar
Default Thanks.. those links are awesome... found a helpful thread... but didn't work>>>>
I can adjust the # value (tried 10-60) in the recode-07 module, but...
when I go to Basic Settings, it shows "error"
and when I try to clear the fault code, the code won't clear.....<ul><li><a href="https://forums.audiworld.com/tt/msgs/775700.phtml">https://forums.audiworld.com/tt/msgs/775700.phtml</a></li></ul>
MNDZA222
17
Nov 24, 2019 09:24 AM
BizarrEftersmak
Jul 21, 2018 10:39 PM
boxster02
May 15, 2008 10:23 AM
Jack Wang
VAG-COM Discussion
Feb 17, 2007 12:13 PM
ivans A8
Nov 4, 2005 07:16 PM
