Ystday, I tried to change my front brake pads on my car. I removed the spring, the 21 mm bolts,....
Old Jul 23, 2007 | 04:20 AM
AUDIctivo's Avatar
Default Ystday, I tried to change my front brake pads on my car. I removed the spring, the 21 mm bolts,....
but the caliper did not come loose. I read the bentley manual, which says to remove the guide pins. Now, my question is what tool do I need to removed those pins? I tried an allen wrench, but the guide pins look like they have a weird shape. Can someone help out?
Old Jul 23, 2007 | 04:37 AM
donp's Avatar
Default pad replacment
If you have HP2 brakes you don't need to unbolt anything. Just remove the spring clip and push the piston back in.
The link below is for an S4 but the HP2 brakes are the same.<ul><li><a href="https://www.audiworld.com/tech/wheel39.shtml">pad replacment</a></li></ul>
Old Jul 23, 2007 | 05:44 AM
JimmyC83's Avatar
Default use a pair of gripped pliers with a flat metal end and simply yank it out the hole...
an adjustable wrench also works just fine...
Old Jul 23, 2007 | 08:23 AM
AUDIctivo's Avatar
I appreciate the help Donp, but I have ATE caliper not the HP2 ones. =)
Old Jul 23, 2007 | 08:32 AM
AUDIctivo's Avatar
Thanks Jimmy. I will try that out when I get home! Hopefully it works!!
Old Jul 23, 2007 | 09:45 AM
JimmyC83's Avatar
Default np, donp's link to the tech article is all u need...
1 person + pads + screwdrivers + brake quiet
and....watch the master resevoir on the brake fluid as it is corrosive...(orange cap in engine bay near battery)
your hardest part will be getting the stupid brake sensor wire cap turned 90 degrees torwards the trunk of the car.... ugh. break it and be done with it =)
Old Jul 23, 2007 | 11:18 AM
S4_Cinci (I S'edTFA)'s Avatar
Member
Default Ate caliper should be 7 mm hex for the guide/slider pins. Make sure you are using one that is long
enough to reach inside the tube that the cap of the pin hides inside...
Old Jul 23, 2007 | 01:40 PM
AUDIctivo's Avatar
Thanks a lot! I am going to try that.
 Pouria Savadkouei
 Michael S. Palmer
lv42dy
RS4 (B7 Platform) Discussion
Dec 11, 2008 05:07 PM
snokarver
Audi allroad
Jul 12, 2008 07:15 PM
Ink Ming
Audi allroad
Nov 19, 2007 02:58 PM
Reinman
Sep 15, 2007 07:13 AM
DesmoTesta
Jul 28, 2006 07:56 PM
