Minor oil leak
Old May 21, 2008 | 08:56 AM
V-Dub Duluth's Avatar
Default Minor oil leak
I replaced the oil cooler gasket back in March, and am still finding small accumulations of oil on the top of the belly pan. The volume has definitely decreased since replacing the oil cooler gasket.
When I was changing the oil last night, the bottom of the oil pan has some oil on it with higher concentrations near the edges. The accumulation on the belly pan lines right up with oil pan.
I am thinking I'll replace the lower oil pan gasket, but is there something else I should be checking? It seems like a pretty straightforward replacement, can anyone confirm?
2001 A6 2.8 w/ 77k on the clock
Thanks!
Old May 21, 2008 | 09:27 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default That's an unlikely place for oil to leak.
Suggest you spend more time looking for the leak before doing anything. Look up at the engine rather than down at the belly pan.
Old May 21, 2008 | 10:23 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Default When the crank seal leaks, oil finds its way EVERYWHERE because of wind....
Change that first..
Old May 21, 2008 | 10:38 AM
audikillsbmw's Avatar
Member
Default Yup.. That's what happened with my oil level sensor leak. It went all over the sway bar, etc.
My crank seal is leaking as well, but not enough to drip.
Old May 21, 2008 | 12:33 PM
BernieBenz's Avatar
That's what the belly pan is for, so you can't find the leak and to keep the oil off the road.
Old May 21, 2008 | 12:35 PM
Default Re: When the crank seal leaks, oil finds its way EVERYWHERE because of wind....
How big of a job is that? If I have the right graphic pulled up in the Bentley, it looks like a big one.
Old May 21, 2008 | 01:47 PM
BernieBenz's Avatar
Usually, most of the wind is in the driver's seat.
Old May 21, 2008 | 03:16 PM
BernieBenz's Avatar
No one (with smarts) changes rotary shaft seals any more! Questionable advice.
 Pouria Savadkouei
 Michael S. Palmer
Old May 21, 2008 | 03:32 PM
R2.7TA6's Avatar
Member
Default check for possible RMS leak...............................
we had an oil leak recently on our 2.7, the oil was sitting in the area right near the oi pan. One shop advised it was the upper pan gasket that was leaking, took it to another shop that was closer and $400.00 cheaper. Turned out to not be the pan gasket but the Rear main seal. Look to see if your getting oil around the front of the tranny seeping through the bell housing and inspection points. Ours was leaking to the point of 1qt per month.
Old May 21, 2008 | 07:01 PM
BernieBenz's Avatar
1 Qt/mo! That's gross! An observant owner w/o belly pan would have fixed early with $5. snake oil.
