Whats wrong with my car, coil pack, bad gas, etc, Thanks!!!
16840 - EVAP System: Very Small Leak Detected
P0456 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16690 - Cylinder 6: Misfire Detected
P0306 - 35-00 - -
16686 - Cylinder 2: Misfire Detected
P0302 - 35-00 - -
16688 - Cylinder 4: Misfire Detected
P0304 - 35-00 - -
16692 - Cylinder 8: Misfire Detected
P0308 - 35-00 - -
16685 - Cylinder 1: Misfire Detected
P0301 - 35-00 - -
16687 - Cylinder 3: Misfire Detected
P0303 - 35-00 -
car was fine cruising about 80 and suddenly starting missing or misfiring. stopped at next exit and car was vibrating and running ruff. shut it down and sat with it off for about ten minutes. still did the same thing after shut down. engine light was on the whole time. felt like it only had about 1/2 the horsepower that it normally does?????
VAG'd it and found the above codes. I reset it and the CEL is off and car is running fine, WTF??
