I was hoping to install my new wheel tonight, but it looks like that's not going to happen : (
...I clearly state that the torx bolts are difficult to reach with a normal tork driver, and a right-angle torx set is the perfect tool for this application. See this <a href="https://www.audiworld.com/tech/elec162.shtml">tech article for more info on the steering wheel removal (from signal stalk replacement tech article)</a>
Oh, and did you obtain the M-12 triple-square for the steering wheel bolt? Not sure if you saw <a href="https://forums.audiworld.com/a6/msgs/790671.phtml">my earlier reply to your question.</a>
I am quite wired...doing laundry, checking e-mail and AW, balancing the checkbook, orgnaizing some files...I should sleep but I CAN'T!!!
