recoding the transmission on a UK 2000 S6 with 00001 coding
Old Jan 7, 2009 | 12:53 AM
technics100's Avatar
Default recoding the transmission on a UK 2000 S6 with 00001 coding
I have a 2000 UK Audi S6 and want to recode the transmission to sport. The current coding is 00001, I have found several links & posts regarding 00002 coding, is it the same only a digit out.. ie... do I recode mine 00031 instead of 00032 as I'm in the UK?
00002, stock coding
00012, sport coding
00022, stock coding, but will hold first gear in Tiptronic to redline regardless of throttle position and then shift to second.
00032, sport coding and will hold first gear in Tiptronic to redline regardless of throttle position and then shift to second.
Also what is the difference between the 22 coding and the 32 coding? They both say the same thing..
Old Jan 7, 2009 | 02:39 AM
basso's Avatar
Re: my02 s6 is set to 32 im in the usa.
Old Jan 7, 2009 | 02:45 AM
Grapeking's Avatar
25 Year Member
Default It is a bit of trial and error on some early model C5s - so go ahead and try
te 00032 (that is what I have in my 2000 2.7T) and if that does not work then try the 00022 or the others. Just note, before starting the process. your current code (the 00001).
For what it is worth, I've tried to code some early model ('98-'99) C5 A6 vehicles and have had success in some and in others the codes would not work - the car just reverted back to stock coding. Not sure why, but it taught me there seems to be no risk in trying the different codes.
Old Jan 7, 2009 | 03:05 AM
Boston Driver's Avatar
AudiWorld Expert
Default difference between "22" and "32" is "stock" vs. "sport"...
...but both will hold tip in 1st longer.
But, as grapeking suggested, no harm in trying different codes. If it is not a valid code, it will not store.
Old Jan 7, 2009 | 03:44 AM
Mine holds 1st to redline now anyway... but should I use 31 instead of 32 as i'm in UK?
Old Jan 7, 2009 | 05:44 AM
AudiWorld Expert
Default No harm in trying it. My guess, is that perhaps the Euro S6 is already coded...
...for sport and to hold 1st longer. If I have a chance, I will look at the bentley codes when I get home tonight.
dvs_dave
Oct 9, 2013 02:06 PM
Serlock
32
Sep 11, 2012 12:24 PM
Devil_Inside
20
Nov 16, 2008 08:55 AM
2.7t @Altitude
2.7T V6 Discussion
May 9, 2008 04:21 PM
800summit
17
Jan 8, 2008 07:47 AM
