NEED A NEW TRANNY :( Anyone have experience?
Anyone know if another transmission is compatible?
Could I switch to Tip?
Repair shop said they didn't find any chunks in the transmission but found some above the valve body while replacing the input and output transpeed sensors. Does this sound right?
Any suggestions are appreciated...
Did the car drive before you brought it in?
If so, why not just change the fluid and filter and see what happens? Or is it terminal?
Just so you know, ABZ is your engine code, not your transmission code. If you have a 97, you either have a DPZ, DSM or DTE transmission. <a href="http://www.audipages.com/Tech_Articles/auto_transmission/autotranservicing.html">This shows you where the nameplate is.</a>
Any of those transmissions can have tiptronic retrofitted to it, <a href="http://www.audipages.com/Tech_Articles/auto_transmission/97tiptronicupgrade.html">Here's what you need to know about it</a>. It's a control issue, not a hardware issue. Just add 3 wires and a new shifter and you've got tip!
pw
PS- I purchased the car with 162k miles for $9k. Good rubber, excellant interior cond.. I just can't see "shooting it dead" at this point. Would like your opinion.
