Twisted the ABS sensor around while the car was running. Now the light stays on all the time.
Old Nov 30, 2004 | 10:17 AM
Mitaka's Avatar
Default Twisted the ABS sensor around while the car was running. Now the light stays on all the time.
I think something is wrong with the cable or the sensor went bad. Where does the other end of the cable go. I have to trace it down. How do you detach the cable from the sensor. In other words any tips will be appreciated.
Old Nov 30, 2004 | 11:03 AM
Rixter 123's Avatar
New Member
Default Mine were reaplaced under warranty
one went bad, twice..... I am not sure if there is more to the problem than we know.
Old Nov 30, 2004 | 06:13 PM
marcodant's Avatar
Junior Member
Default Re: Twisted the ABS sensor around while the car was running. Now the light stays on all the time.
depends on the driver side it is easy to get too look under the abs pump I think and you should see the plug. on the passenger side it is under the airbox.. have to take the whole air box out. sounds like you have a open (broken wire). cut it near the sensor (leave enough room to solder and then near the plug side and solder in 2 new wires. Only do this much of the wire if you don't know where the open is. for me mine was about 6inches up from the abs sensor itself. don't forget to remove the rubber groumts and reuse them. they keep all the wires in place and from getting twisted or pinched.
Mumawalde
Aug 16, 2010 05:48 PM
Pupek
1.8T Discussion
Mar 16, 2009 05:37 AM
VorsprungTT
Dec 11, 2007 03:43 AM
AudiLurker
Feb 20, 2005 03:56 AM
marcodant
Oct 28, 2004 03:03 PM
