Just added Mobil 1 0w-30 racing to the car, and changed the sparkplugs...Randy, have you made...
Old Dec 7, 2004 | 08:41 AM
GrA8ful S8's Avatar
New Member
Default Just added Mobil 1 0w-30 racing to the car, and changed the sparkplugs...Randy, have you made...
...it to 5000 miles with the 0w30R yet? I remember that you said you were going to take a sample of it and have it analyzed at Blackstone Labs...
It could be just me, but it feels like the engine is more "free flowing" now, and maybe a bit faster. I know it is probably my mind playing tricks because I want those results...but it is possible. I changed from mobil 1 0w-40.
Old Dec 7, 2004 | 10:09 AM
ryoung's Avatar
Elder Member
Default Only have ~3000 miles on the oil so far ...
Let us know if you see a similar jump in gas mileage.
Old Dec 7, 2004 | 10:32 AM
borden's Avatar
what about mobile 0w20--can we use that?? It appears that 0w30 is no longer available at pepboys.
Old Dec 7, 2004 | 01:19 PM
ryoung's Avatar
Elder Member
Default I would not use Mobil 1 0w-20.
The cam profile in 4.2L is fairly aggressive, and I'd be worried about cam lobe wear with 0w-20.
Also <A HREF="http://store.avlube.com/mo1r0wraoil.html">Mobile 1 0w-30 Racing</a> is not your normal Mobil 1 0w-30. The racing version contains much higher levels of anti-wear additives, and as far as I know, has never been available off-the-shelf anywhere.
Old Dec 7, 2004 | 02:04 PM
GrA8ful S8's Avatar
New Member
Default Over the last 4 months I have averaged 16.0 mpg per the car computer, I am resetting it today.....
....i will advise.
Randy,
You are of the opinion that the 0w-30 racing mobil one is the best oil we could use for the S8, right? I noticed that you were nervous about adding the oil until your warranty was up. Please advise. From what I have been reading, it seems that it should have no issues, and our cars may only benefit from it. Please advise, thanks.
By the way, I bought the 0w-30 racing at Murrays Discount Auto for $7.99/quart off of the shelf. They are located in Michigan and Ohio, maybe Penn. Check out the website for locations. The dealer performed the oil change, and they had no objections to using this particular oil...
Old Dec 7, 2004 | 02:39 PM
ryoung's Avatar
Elder Member
Default three opinions
1. <i>"You are of the opinion that the 0w-30 racing mobil one is the best oil we could use for the S8, right?"</i>
- Correct
2. <i>"I noticed that you were nervous about adding the oil until your warranty was up. Please advise."</i>
- The concentration of phosphorus (from an anti-wear additive) in Mobil 1 0w-30R exceeds the maximum allowed by API. As a result, since the oil has no API rating, it technically does not meet the specs for an approved A8/S8 oil. I suppose a hard-nosed dealer could use this as a reason to deny a warranty claim.
3. <i>"From what I have been reading, it seems that it should have no issues, and our cars may only benefit from it. Please advise."</i>
- Correct. The only potential issue at all is that if the motor burns excessive amounts of oil, those high levels of phosphorus could poison the catalytic converters (which is the only reason that API has a max P spec). The ISLAC GF-3 Standard's phosphorus specification is 1000 ppm max (GF-4 will me 800 ppm max), the 0w-30R runs ~1400. I'm not going to lose any sleep over this, and besides, I wouldn't be using an $8/qt oil in an oil burning car.
Old Dec 7, 2004 | 04:34 PM
tozoM8's Avatar
Tech Guru
Wal mart has it for less than $5 Mobil 1 0w-30.
Old Dec 7, 2004 | 05:25 PM
GrA8ful S8's Avatar
New Member
three thanks!!!! i trust your judgement.
 Pouria Savadkouei
 Michael S. Palmer
Silver Streakin'
Jan 10, 2007 01:14 PM
SteveIAS8
12
Feb 12, 2006 03:57 PM
TT-Square
Nov 15, 2004 01:21 PM
darkque
Oct 24, 2004 01:08 PM
Stephen K
Nov 28, 1999 03:39 PM
