OK...transmission rebuilt
Old Sep 23, 2005 | 09:16 AM
Phillip852's Avatar
New Member
Default OK...transmission rebuilt
2000 A8L no reverse = $ 3500.00
2000 A8L shifting smoothly = priceless
However still have 2 problems that are driving me crazy. Both are warning lights in the instrument cluster.
1)"brake pads worn" light
Pads and rotors replaced 2000 miles ago, however the pad worn sensor plug on the new front pads was not the same...my mechanic spliced them together and heat shrank them and all worked fine for about 1800 miles now comes on every time I start the car.
2)"headlight/tail lights malfuntion switch" comes on intermittently whether I turn the lights on or not, once on stays on. Checked all bulbs and cannot find a bad one. The trans shop ran Vag Com and said a code came on that indicate to him that I may have tried to adjust the headlamps (which I have not) He cleared the code and when I picked up the car it was off but now after under 100 miles has started again.
Any ideas? It is more an annoyance than anything else but I would really like to have the car "right"
Old Sep 23, 2005 | 09:23 AM
legendGuy's Avatar
New Member
Default Re: OK...transmission rebuilt
Where did you have the transmission rebuilt?
Old Sep 23, 2005 | 09:31 AM
Phillip852's Avatar
New Member
AutoHaus in Royal Oak, Michigan
Old Sep 23, 2005 | 09:48 AM
Jim II's Avatar
Default Pad light is an open circuit. If you can't find the cut in the wire....
I think Paul has a link (audipages.com) on how to take out the dash and close the circuit for good at the dash. That's what I did after listening to the beep and the light comming on for over a year.
Old Sep 23, 2005 | 10:07 AM
PaulW's Avatar
Default Here's the procedure to get rid of it once and for all
<ul><li><a href="https://forums.audiworld.com/a8/msgs/92906.phtml">I need to post this on audipages</a></li></ul>
Old Sep 23, 2005 | 10:24 AM
Phillip852's Avatar
New Member
Default Re: Here's the procedure to get rid of it once and for all
Thank you Paul....not to mechanically inclined but i think I can handle that one.
Any Ideas for the bulb out indicator?
Old Sep 23, 2005 | 11:28 AM
PaulW's Avatar
Default Be careful, that wiring diagram is for the 97-99's
The 00 could be different, would have to look at the wiring diagrams first. I know the connectors on the back of the cluster are different.
lentiman
Q7 MK 1 Discussion
Apr 8, 2019 10:39 AM
Audipdx
14
Sep 16, 2009 02:58 PM
kjb99
Apr 20, 2005 09:55 AM
SpfldS4
20
Apr 20, 2004 09:27 AM
j14
Feb 28, 2002 06:46 PM
