overheating
the damn thing still overheats while idleing...
Maybe next i need to cut out some vents... its crazy...
its definately air related.. ideas?
Behind the drivers side front wheel there is a ground plate with 3 ground posts and 4 or 5 wires grounded there. I had a similar overheating problem and noticed that one of the grounding screws had corroded and broken off leaving a loose wire. The other 2 were on their way out as well so I removed the plate and drilled out the old bolts. Replaced the ground posts with screws and reconnected everything.
