Timing belt on ABZ question
Old Oct 4, 2005 | 10:03 AM
Dr.  Jitter's Avatar
New Member
Default Timing belt on ABZ question
Open right timing belt cover and measure tension damper length - 15 cm on cold mashine (13.8 cm maximum on new belt). Am I need to replace belt ?
Old Oct 4, 2005 | 10:20 AM
PaulW's Avatar
Default Hard to tell
The timing belt should be replaced due to age or miles.
Over time it stretches slightly, which causes the damper length to change to make up for this change.
This is what causing the valve train and crank timing to change slightly.
Why did you pull the cover off?
Old Oct 4, 2005 | 10:31 AM
Dr.  Jitter's Avatar
New Member
Default To check previous owner
First: I don't know when it replaced.
Second: I think, that previous owner didn't replace rollers properly when he replaced belt (He was very mean )
I have this car about 1 year
How Bizarre
Sep 4, 2007 09:10 AM
bradstera2
Audi Original "S" Cars
Apr 15, 2006 03:40 PM
helpmeplease!
Apr 1, 2006 02:27 PM
Dave R.
May 15, 2005 08:16 PM
A4orce84
Feb 3, 2005 06:14 AM
