my seat memory buttons popped out
the question.. should i just remove the springs and let them sit in place.. or do i replace these buttons, and if so, where do i get replacements
Before I let her into the car, I start the car, press black memory button then #1. I turn the memory off using the red button to ensure it doesn't store the changes she's going to make.
Problem is that when I get in the car the next day push the red to turm memory on and press #1 to get my setting it lifts the wheel way up and the seat forward. The seat has never been in that position!!
Can't figure it out.
You may also need to reassign the memory position to based on which remote unlocks the car... Search around on here, people have posted that procedure before too...
I had a similar problem with the settings not storing properly. I think my button 1 is just dead. I re-memorized my settings to button 3, and reassigned my remote to button 3, so now it works.
Didn't know the key was an issue. Mine is used always except when I drop it to the garage for work.
Thanks
