Transmission Failure?
Check fuses relays
Treat the beast to a trans flush and fluid level check -clear codes then if no go follow this with a tech that cares-seems a big assumption that the trans is kaput given this info.
the real meaning is he doesnt know where to start.
Find a good trans specailist and provide him with detailed diagnosis info.
If more from manuals is required please email me
Output on printer
Possible cause of fault
How to rectify fault
17114 P0730
Gear/ratio monitoring
Wrong ratio
- Gearbox output speed sender -G195 faulty
- Rectify fault as described under fault code 17105 / P0721
- ATF-level not OK or ATF contaminated
- Check ATF level
- Clutch slipping/defective
- or solenoid valve dirty/defective
- Check ATF for contamination
Notes re fault recognition for fault code 17114 / P0730:
? The gear monitoring system in the gearbox control unit checks the ratios by comparing the engine output and gearbox output speeds for whichever gear is engaged. The above fault code is displayed if an incorrect gear ratio (implausible signal) is detected.
? When testing the stall speed, the gearbox input speed in the torque converter should be approximately 0 rpm with the vehicle stationary and a gear engaged. If this is not the case, the above fault code will be displayed to indicate possible clutch damage (see "Reading measured value block" =>Page 01-115; Display Group 001
17105 P0721
Sensor for Gear output speed -G195
Implausible signal
- Open circuit or short circuit to earth or positive
- Check wiring and connectors according to current flow diagram 5)
- Screening for -G195 defective
- Gearbox output speed sender -G195defective
- Read measured value block =>Page
Continued ?
