Help, only reverse and second gear!
Old Jan 10, 2010 | 09:47 PM
boosted7's Avatar
Default Help, only reverse and second gear!
96, 2.8, Auto.
Only moves in reverse or 2nd. If i put it in drive it slips completely/revs freely.
Suggestions?
Old Jan 10, 2010 | 10:15 PM
Hightone64's Avatar
Sounds like your transmission is bad, I dont think you can do anything but put in a new trasmission
Old Jan 11, 2010 | 04:06 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Codes? Have you checked fluid level? Any basic trouble shooting done?
Old Jan 11, 2010 | 08:57 AM
boosted7's Avatar
I'll pull the codes in a bit.
I haven't got anything for tools where I am so I"ll have to bring it to a shop for the fluid check but if i get it to a shop I was thinking about getting the fluid changed with the filter if you guys think it might be the culprit...
Old Jan 11, 2010 | 11:10 AM
4Driver4's Avatar
Tech Guru
Tech Guru
A fluid change is expensive. I'd start by just borrowing a VAG-COM and checking the level and pulling the codes on your own.
Old Jan 11, 2010 | 11:27 AM
boosted7's Avatar
No codes. Can I check the level with the vag com?
Old Jan 11, 2010 | 12:53 PM
4Driver4's Avatar
Tech Guru
Tech Guru
You can't check the level with the VAG-COM, and you shouldn't try to check it without VAG-COM.
Cryptic enough?
Level is checked manually via a stand pipe in the transmission pan. You remove the plug and pump in fluid (the right fluid) until it runs out again. But (and here's the VAG-COM part) the trans temp needs to be between 35 and 45 degrees C.
Basically, you raise and level the car, then start the engine. Fire up VAG-COM to begin monitoring trans temp. With the car running and in Park, pump as much fluid as you can into the trans through the fill hole. Stop when it runs back out. Wait until the temp reaches about 37 degrees, then put the plug back in.
lrwatkins
Sep 13, 2010 05:44 AM
eyedrive
Apr 23, 2007 08:39 AM
MRSK
Dec 31, 2006 08:35 AM
roughyear
10
Jan 28, 2006 12:13 PM
bfoxg8r
Audi 100 / A6 (C4 Platform)
11
Apr 10, 2004 08:10 AM
