Turn signal fixed in the TTQ
The tech told me they think a wire worked loose, then rubbed until it started making intermittent contact.
In the event that anyone's TT has a turn signal problem that isn't caused by a bulb, this is something you should have them investigate...
--Joe
I am trying to track whether changes are being made to the production lines to correct known bugs. If this one isn't fixed, I think it may be time to write my letter. The right tail light assembly also had the same bad wiring, and my tech was astute enough to look and fix it.
I can better understand that the instrument clusters aren't fixed yet since they are pretty complex little computers. But to not have fixed a PROCESS on the assembly line is unnaceptable and speaks volumes for Audi's production processes in my opinion.
Of course, if it was not in the tail light assembly then I just typed all that for nuthin!
Ivan
