Is it normal for TT's to track (pull) to the right?
I'm going to have my TT aligned soon.<p>David
Desert Green TTQ, H&R Springs, BBS wheels, Borla
It is hard to find a flat concrete surface. Try a big mall parking lot of something.
On the other hand, I went through a whole set of tires on my Camry before I stopped complaining to the Toyota dealer who had "tried" 4 times and took it to a tire shop who happened to spend the time to get the alignment right!
HTH
Ivan<p>Ivan
<i>Jacksonville, Florida<i>
<img SRC="http://www.geocities.com/y2ktturbo/tinytt.jpg" BORDER=0>
"Zorro" 2000MY, 180hp, Fronttrak, Silver/Ebony
K&N, Garmin EMap GPS, Audi "mask", Cobra R/D
I've found optimal handling/steering is with the tire pressure set at the recommendations inside the gas cap. That might help.
To check for radial tire pull, swap the left and right front tire/wheel then road test. If no change, swap them back, then swap the left and right rear. If the pull changes to the other direction after the swap then you definetely have identified a radial pull. You might be able to increment the tire pressure of the tire opposite from the pull by a 1/4 to 1/2 lb to keep the tracking true. Adjust pressures only when the tire is completely cold.
If you have a lot of miles on the tires, then replacing them may be the only alternative since as a radial tire wears in, the radial belts settle in and adjust to the camber of the wheel and a left right swap would only worsen the problem.
Good luck. We had a Subaru with the same problem and fixed it with a swap and a bit of air on the opposing side.<p><img SRC="http://www.mint.net/~kentech/auditt/ttsig.jpg" BORDER=0>
<p><font color=#800080><b><i>So many pylons, so little time ...</i></b></font></p
I will check the tire pressures in the morning, but under Florida lemon law I have options but dont want to end up getting another TT just to have it be the same way.
i have tried going onto the other side of the road and the slope was slightly the other side, and the car pull to the other side. that's proved that the steering pulling was due to the sloping of the road by not the alignment.
of cors when u hold the steering wheel straight the car should go straight. I am getting used to the pulling now.<p>180FWD/Wetterauer/Remus/Pipercross Air Filter/PIAA/17" BBS RXII
