"blow-by"valve replacement
Old Apr 13, 2001 | 01:48 PM
hsm's Avatar
hsm
New Member
Default "blow-by"valve replacement
I know this is not the correct name for the valve that people are replacing with the "Bailey-forge". I decided to have Audi replace my bad valve with their new replacement valve. Have had it in for about a month-my impression is that the car has less power throughout its range, but most noticeably on the top-end.
Has anybody else replaced their valve with the new Audi valve? If so, have you noticed a change for the better or worse. My original was making noise, but I was not experiencing any power loss-guess I should have lived with the noise.
Thanks for any info.
Old Apr 13, 2001 | 02:21 PM
TTurbo's Avatar
Default You shouldn't have to live with the noise because it's defective, it WILL go out....................
possibly when you least expect. My valve is making a slight noise and I know I have a lot of low end power loss on my 225. I am not to far from my 5000m service and will get mine replaced with the new valve. From what I have heard of the valve, so far so good. One can only hope. -Doug
Old Apr 13, 2001 | 03:10 PM
225TTR's Avatar
Senior Member
Default Audi has had a series of 'new' valves and AFAIK they have yet to find a permanent fix. Do yourself
a favor and get a quality valve such as the Bailey or the Forge. The OEM valve is a POS.
Old Apr 13, 2001 | 03:11 PM
225TTR's Avatar
Senior Member
If they're still on the 'N' series valve, don't get your hopes up too high.
Old Apr 15, 2001 | 05:07 AM
BillK's Avatar
Default If it's noisy, dealer will replace it...
Current valve is the "N" valve.
I've stayed stock because frankly I've not experienced the noise and I don't want to risk my warranty...
shon84
Q5/SQ5 MKI (8R) Discussion
Feb 28, 2017 11:04 AM
da A4 kid
Jan 29, 2004 06:48 PM
Petemic
Audi 100 / A6 (C4 Platform)
Aug 14, 2003 06:15 PM
hoTTflash1
Mar 14, 2002 12:40 PM
hsm
Jul 22, 2001 05:22 AM
