squeaky front end..
Old Jun 21, 2001 | 04:54 AM
juliem's Avatar
Default squeaky front end..
Someone posted about a squeak up front in their TT - mine's doing it and I think it's the rubber bushing in our fine mkII control arms. But I'm guessing of course.
Anyone with the original front suspension have squeaks? I'm curious if others who have squeaks would post - mine happens easily going over a speed bump slowly for example.
My car has ~13k miles on it and the squeak is a recent symptom.
Cures or bandaids only?
cheers
Old Jun 21, 2001 | 05:01 AM
TTurbo's Avatar
You haven't been through any moderate water lately have you??
Old Jun 21, 2001 | 05:18 AM
juliem's Avatar
Default not especially but even when hot and dry? (humid as hell) it squeaks
didn't do this last hot, humid summer
Old Jun 21, 2001 | 05:44 AM
TTop Gun's Avatar
Member
Likely the front swaybar bushings. Common problem on VW's.
Old Jun 21, 2001 | 06:16 AM
MichaelTT's Avatar
Senior Member
Default To verify source...hit sway bar bushings...one at a time with some WD40 (spray one...drive...
then do next one) and then same process for lower control arms...eventually will isolate source if indeed it is a bushing etc. Just a thought...
Old Jun 21, 2001 | 06:36 AM
juliem's Avatar
thanks, will do
Old Jun 21, 2001 | 07:04 AM
asmarks's Avatar
New Member
Default Re: squeaky front end..
That would be me. Does the squeak occur right away or do you have to drive the car some before you hear it? It was the bushings. They were removed, cleaned and re-lubricated using Dow Silicone 111 lubricant. They first tried a copper anti-seize lubricant but that did not work. Tell your service guy to contact Ray the Service Manager at Bernarid Audi in Natick, MA for details or e-mail me and I'll provide any additional info I may have.
Old Jun 21, 2001 | 09:41 AM
juliem's Avatar
Default It might happen always but there's other noise..
Easy to hear going slow over a speed bump, plus it helps seperate out the front end from the back end sounds.
I actually know Ray at Bernardi, thanks!
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 21, 2001 | 04:14 PM
cubstter's Avatar
Senior Member
Julie, that was me. have them replace the bushings and check the swaybar. so far, no problems.
Old Jun 21, 2001 | 07:07 PM
juliem's Avatar
Default Re: Julie, that was me. have them replace the bushings and check the swaybar. so far, no problems.
cool. Doesn't sound like fun
Boosted_4cyl
Sep 30, 2007 02:32 PM
5spdJunkie
Jun 17, 2006 07:15 PM
Jim - 03S8
Apr 6, 2005 06:58 AM
Swank4
Mar 2, 2004 09:10 PM
deosola
Apr 29, 2001 11:30 AM
