Major stress crack appeared on my windshield today (also a fuel sensor question)
Is this a common area to get them;
Is there a service bulletin for it; and
Has anybody had any problems getting their dealer to replace.
This was a problem common to early 225's(which TToad is) which was eventually solved, right?
My fuel guage is also acting up and I'm sure its the bad sensor. Is there a service bulletin for this one?
TToad is going in for its 12 month service on Monday so the windshield is timely, I guess!
TIA,
BarTT
Don't know much about the sensor thing though - sorry.
Good luck with it all and let us know how it goes with your dealer.
Called the dealer and set up an appointment. Was told they take a digital picture and forward to the audi rep for approval under warranty. They wanted to be sure crack was not due to rock etc. I went loaded for bear. Searched this forum and found a least 30 people with the same problem. Took a print out of a select few and handed them to the service manager and stated that this was a known problem. Glass was replaced under warranty.
Only one problem. Dealer damaged 2 new pieces of glass during the install so it took 3 pieces to get it right. Also sratched the clearcoat on the hood in the process which i did not see until i got home. Also for some unknown reason one of the plastic pieces under the hood that covers the fan was missing. I noticed this because one of the clips that hold my hood cover in place was hanging outside of the hood. Brought the carback the next morning and the service manaer had no clue as to why the part was missing as it is held in place with 3 screws. He replaced the part righ away. jury still out on the scratches.
Do not let the dealer give you the run around. Stress fracture is covered under warranty.
Sorry to take so long.
