Check Engine Idiot light came on last night....
Old Aug 15, 2001 | 07:14 AM
BigTT's Avatar
Member
Default Check Engine Idiot light came on last night....
Was driving to a friends for dinner last night and the check engine light came on... freaked me out since I have never had that happen on any of my previous cars...
To make a long story short: checked the oil - 1/2qt low, coolant level correct, DV connections were tight. What else could cause this..... the engine sounds and feels perfectly normal. I've had a problem with a sticky Forge DV, buy I re-lubed it on Saturday with some hi-temp antiseize lubricant. The DV sounds like it is actuating properly.... Also, I added some 110 octane race gas on Sunday for our local drive. I only added 2.5 gallons mixed with 91.
One thing that I'm suspicious of is that the clowns at the dealer did not reset my service reminder to the 10K interval the last time there... for the past 5K, the service indicator has been lit every time I start the car.... could Audi have been that smart to throw in an additional service "warning" by lighting the check engine light???? (I just reached the 5k point since the service indicator started to come on)
The car has not stumbled or acted in any way abnormal.... was driving, looked down and saw the light was on....
Any one have any thoughts???? I'm scheduled for my 20K service next wednesday. should I wait till then??
TIA
Old Aug 15, 2001 | 07:18 AM
TTeleven's Avatar
Could be one of numerous reasons - unless you are in limp mode don't worry about it
Old Aug 15, 2001 | 07:19 AM
Rennen's Avatar
Elder Member
Default It can be any one of many posibilities and it can only be diagnosed by checking the DTCs with a VAG.
Since you're not experiencing any drivability problems, it's probably something very simple like a broken sensor or a vacuum leak.
Old Aug 15, 2001 | 07:20 AM
Jim TT's Avatar
Default It is not the service light- it could any number of things, if the CEL is not blinking then it is
..safe to drive the car. You have some fault codes, of that there is no doubt. If you know someone with a VAG tool they can read them. Otherwise take the car to the dealer. JIM
Old Aug 15, 2001 | 07:22 AM
UCFJWH's Avatar
Default Same proble here...
Fuel sending unit was leaking. Caused a vacuum problem. It may also be a loose gas cap.
Old Aug 15, 2001 | 08:14 AM
BigTT's Avatar
Member
Thanks Guys!!! I can breath a little easier now.....
haridass86
A4 (B8 Platform) Discussion
Aug 8, 2018 03:33 PM
jigglyjams
A4 (B7 Platform) Discussion
Jan 15, 2010 03:37 AM
CJKCyclone
Feb 28, 2003 07:09 AM
Mark F.M.
Audi allroad
Jul 13, 2001 06:07 AM
