Creaky Coilover solution? ....
Old Sep 19, 2001 | 11:16 PM
sTTanford's Avatar
Junior Member
Default Creaky Coilover solution? ....
Now I know coilovers are generally creaky, but I remember somebody talking about an A4 with coilovers and a plastic/hard rubber insert that helped dampen the creaking.
I'm not too knowledgable about coilovers, but just from listening to the creaking, it sounds like its from the contact point between the springs and the shocks (I can't think of anything else that'd creak). On that note, would it be possible to insert a small spacer, maybe 1/16" or 1/8" thick, made of a hard rubber or plastic, that will dampen some of the creaking? I swear i heard of somebody doing this....
opinions?
Old Sep 19, 2001 | 11:30 PM
Lloyd of the Rings's Avatar
Default Yep; when I had H&R coilovers, Terry did something magic....
either wrapping the springs in plastic wrap or putting a small rubber insert in (I don't remeber) and that fixed the problem.
Old Sep 19, 2001 | 11:46 PM
sTTanford's Avatar
Junior Member
Default he mentioned you...
.. but I dont think he "worked his magic" when he installed mine. They creak like a bat outta hell.
Man, its impossible to take 6 hours out of my day to drive back back and forth from berkeley during the week. its really too bad Terry isn't open weekends... I guess if I stay up there while he checks it out it won't take as long...
I'll email him.
Btw, Chris, what area you from?
Old Sep 20, 2001 | 05:43 AM
dbear's Avatar
New Member
Default Re: Creaky Coilover solution? ....
I am about to buy and install the bilstein PSS9's on my TTQ Coupe. What's this about creaking? Is that just a breaking in kida creak or is it constant with all coilovers?
Old Sep 20, 2001 | 07:12 AM
sTTanford's Avatar
Junior Member
Default most coilovers creak...
in my limited experience (ie, most of my friends' cars that have coilovers in them creaked to a certain degree). You've got the same amount of force being absorbed by a smaller and tighter spring.
Terry Griffin (www.g-werke.com) mentioned dthat he didn't like the PSS9s because even though it is great to have a "9-way adjustable" ride, as soon as you adjust anything its going to unbalance the coilover, and affect alignment - basically, you can't simply adjust one setting, you have to balance them all.
I hope I repeated what he told me correctly, but if you want his not-very-humble opinion, he recommends H&Rs over anyother coilover system. I put them in and they ride wonderfully, for street use and more aggressive use.
If you do install the coilovers, ask whoever is installing it about inserting some sort of rubber insert. if you tell them that TT coilovers are notorious for creaking in the rear (front doesnt creak) they might know what to do...
PS, A bunch of ppl have H&Rs, and PSS9s, so if you ask around ppl can send you pics so you can check out ride height. i'll get my pics up soon.
Old Sep 20, 2001 | 11:09 AM
I live in Novato...8 miles from Sears Point
SolidFish
Sep 27, 2004 01:35 PM
a4racer
Jan 25, 2002 10:14 PM
JoshK-Allroad
Mar 30, 2001 03:50 AM
Bill D
13
Jan 11, 2000 07:40 PM
