Adding MP3 player (JVC KD-SH99)
YES but doesnt have any info about NON BOSE systems (which I might be confused about but the base system is NON Bose right?) Also does the KD-SH99 mount flat enough so that there is clearence for the TT door to close on it?? also does the remote work thru the closed door? Obviously Im a complete beginner and need some help here. Any will be greatly appreciated.
https://forums.audiworld.com/tt/msgs/366769.phtml
If your MP3 player has pre-amp outputs as well as speaker outputs, you are OK.
Use the speaker outputs to drive the front speakers, and the pre-amp outputs, to wire into the harness, to drive the power amp in the rear of the car.
If all you have are pre-amp outputs from the MP3 player, you are hosed. You will have to find another amp to drive the front speakers<ul><li><a href="https://forums.audiworld.com/tt/msgs/356914.phtml">Wiring in a different Head unit.</a></li></ul>
You can wire this unit directlty into the existing TT wire harness.
The front speaker outputs go the to front speakers, and the pre-amp output for the rear, go to the existing power amp.
It's easy.
Then the pre out hooks up to the with the rear amp that powers the "rear" speaker and the sunwoofer. By rear I assume you mean the ones in the panel behind the seats.
A couple of questions...
Does this apply to Bose and non-Bose systems in the Roadster?
If the head unit is going to power the front speakrs, can you change the front speakers to whatever you want?
Thanks
I do not know if this applies for the "Bose" upgrade.
I suspect that the fact the upgrade system in the roadster, calls for a "5-channel" amp, that the upgrade amp runs all 5 speakers.
If you look closely at the label from the 'Concert' radio, you will see pre-amp outs for LF,LR,RR,LR.
Yes, you can then replace the front speakers with anything else. They are 4 ohm.
Take the door panel off, and you will see.
They are 6.5" mid's and 2" tweeters.
So I wonder if I could just replace the front speakers and run them off of the new H.U. or a seperate amp just for them.
Whaddaya think?
