Electrical question
Old Oct 26, 2001 | 06:04 PM
sTTefan's Avatar
New Member
Default Electrical question
I have wired up a DB25 crossover and an RJ45 with Cat5 wire (according to info found in the FAQ's)to try and supply power to the center console. I have tested all of the connections for continuity, but can not seem to get the handsfree kit (a cellport) to power up.
How can I test to see if the power is being delivered to the console? I have a multimeter that I borrowed from a friend, just not sure exactly how to test it?
Any suggestions from the more electronicly inclined would be appreciated.
Old Oct 26, 2001 | 06:26 PM
DaleS's Avatar
Junior Member
Default You want to probe with the multimeter this way...
set to DC voltage
place the black probe on the wire carrying ground (GND)
place the red probe on the wire carrying +12 (Batt+)
The voltmeter should read out 12VDC +/- a couple of volts (cars can put their electricals at +14VDC when running, and +10VDC if not).
If you're not getting voltage, I'd go to the continuity mode (ohms) and double check your db25 loopback to make sure that there is 0ohms (looks like a greek omega sign) between the pins you jumpered for the Batt+ and GND.....if that checks out ok, then check the db25 in the rear of the car to see if there's 12vdc between the db25 pins.
If you're in Denver you could stop by
Good luck,
Dale
Old Oct 26, 2001 | 07:08 PM
sTTefan's Avatar
New Member
Thanks! I'll try it in the morning.
Old Oct 27, 2001 | 07:41 AM
JustJeff's Avatar
It's possible you reveresd the leads from the RJ-45 jack also, it's easy to do.
Old Oct 27, 2001 | 09:06 AM
sTTefan's Avatar
New Member
Can you suggest how to know what is pin 1 and what is pin 8?
Old Oct 27, 2001 | 01:48 PM
JustJeff's Avatar
Default Yes, looking at end of the RJ-45 cable, with the tab pointing down, pin 1 is on your right.
Are you using this schematic?
<img src="http://mk1tt.montebellopark.com/images/ttphoneschem.jpg">
Old Oct 27, 2001 | 02:05 PM
sTTefan's Avatar
New Member
Thanks, I was looking at this schematic, but was reading it backwards
BEM-S4
Telematics Discussion
Dec 9, 2005 03:43 PM
bluenote
Feb 11, 2004 01:52 PM
Mark.core
Oct 8, 2003 10:10 AM
philly audi kid
Sep 24, 2003 01:14 PM
muvment
May 1, 2003 07:06 AM
