Your experience with a rattle is needed
Has anyone found a specific problem area or a fix for this. I know if I tell the dealer they will just say they can't find it. Thanks for any input.
Do you think the rattle has anything to do with engine or car speed? Do road conditions play any part in this? It could also be a heat shield and or the exhaust itself. The dealer would check on these two items for you if you don't have a means to check them yourself.
I don't know if the coupe doors are the same but the roadster door has a wedge of black plastic which sticks out from the door under the latch. As the car flexed/accelerated... there would be a rattle which sounded like it was coming from above and behind the passenger seat. I put some thick plastic tape on the wedge to tighten the fit and the rattle has gone away.
