OEM phone handle installation ?
Old Oct 29, 2001 | 10:38 AM
sTTefan's Avatar
New Member
Default OEM phone handle installation ?
<center><img src="http://www.noir.net/~stefan/tt/blob-47996.jpg"></center><p>Hello all-
I was wondering if someone out there that had installed the OEM phone holder (the aluminum one that goes in the center console - see pic) could lend some advice on how to do it? The best I can figure is that the front passenger seat has to come out. Can anyone give me an idea how to do this?
Old Oct 29, 2001 | 11:05 AM
TTeleven's Avatar
Default I've installed the bracket twice .....
<center><img src="http://pictureposter.audiworld.com/11/ttr-phoneb.jpg"></center><p>
and removed it once
The seat does not have to be removed.
Place the seat in the low position and as far back as it will go.
You also need a small ratchet wrench (Sears)
to tighten the star head bolt.
You will have to start the bolts by hand then get the wrench in between the seat but you
can push the bolster toward the passenger door also.
By playing with the seat position you can readily gain access to each of the bolts securing the bracket.
regards
Kevin
Old Oct 29, 2001 | 11:11 AM
sTTefan's Avatar
New Member
Thanks, I'll have to try that!
Old Oct 29, 2001 | 11:44 AM
St3phen's Avatar
Default A trick I found is to remove the
little yellow plastic 'nuts' from inside the tunnel. Do this carefully, b/c you'll cry if you drop one inside the tunnel. Then, thread the supplied bolts into the nuts back & forth a couple of times while they're out so that you're not trying to accomplish two things while they're in place.
Another hint is to place newspaper or other similar materials under the area you're working on <I>above the seat runners</I> so that when you inevitably drop a bolt, you won't waste 20 minutes trying to get it out.
Lastly, I used a special right-angle bit driver available from Sears. The depth is about 1.25" including the bit. (Actually, this tool has come in handy <U>many</U> times over the years. If you use a tool like this, put something protective between the tool and the seat leather.
Old Oct 29, 2001 | 11:53 AM
jeffmc's Avatar
New Member
Default Re: I've installed the bracket twice .....
Ok, looks good there.
Is the bracket available from dealer's part shops?
JeffMc
Old Oct 29, 2001 | 04:41 PM
economisTT's Avatar
could be...but they may have to order it for you...clair parts has them in stock.
Old Oct 29, 2001 | 06:46 PM
sTTefan's Avatar
New Member
Where did you get the bracket mounted to the OEM holder?
MC Hammered
Pacific Northwest Discussion
12
Oct 20, 2008 01:18 PM
austin.schipper
Nov 25, 2007 04:53 PM
Jet Jockey/A4 Pilot
Canadian Discussion
May 24, 2004 12:59 PM
Jet Jockey/A4 Pilot
21
May 24, 2004 10:18 AM
BiturboBoy_V2.0_S3--
33
Sep 16, 2003 11:19 AM
