VAGCOM - DTC 17536 - System Too Lean ?!?
Old Oct 30, 2001 | 04:08 AM
Ron G's Avatar
Default VAGCOM - DTC 17536 - System Too Lean ?!?
After autocrossing this weekend, the Check Engine Light came on so I checked it out and saw the following code:
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
35-00 - -
I tried looking for info on the RB CD, but couldn't find anything (maybe I'm not looking for the right thing?).
Anyone have any ideas?
Old Oct 30, 2001 | 04:14 AM
Rennen's Avatar
Elder Member
Possibly your MAF sensor is having a problem.
Old Oct 30, 2001 | 04:17 AM
Ron G's Avatar
Anyway to check that? I'm new at this VAGCOM stuff.
Old Oct 30, 2001 | 04:35 AM
Rennen's Avatar
Elder Member
Default I don't know. You can contact Uwe, though, with VAG.COM and he should be able to tell you.
You can also join their mailing list and post a question to that group.
Old Oct 30, 2001 | 07:31 AM
Gerg's Avatar
New Member
Default I had this problem... for me it was a bad MAF
To troubleshoot I followed these instructions from the VAG-COM eGroup on yahoo:
> Check measuring block 32, and check
> the 1st and second fields. If the second field is over 10 it's
> not good. At 20 the lean code tends to set. The first field is
> low, (idle correction off of field 2) and field 2 is high (driving
> mixture) the MAF is the likely cause.
The link to the post is below.
I hope you're still under warranty because a new MAF runs close to $400.
Greg.
2000 180TTQ<ul><li><a href="http://groups.yahoo.com/group/VAG-COM/message/1515">http://groups.yahoo.com/group/VAG-COM/message/1515</a</li></ul>
Old Oct 30, 2001 | 08:12 AM
tks's Avatar
tks
New Member
ditto, same CEL, same fault code, final solution MAF
Old Oct 31, 2001 | 02:08 AM
Ron G's Avatar
Default Thanks, I'll check it out. Also from Bentley, it could be oil thinning ...
need to get the oil changed - longer than normal, so that could be the problem.
groovninja
VAG-COM Discussion
Nov 16, 2006 09:26 PM
TighTT
Aug 14, 2005 11:17 AM
andrew.tt
Mar 5, 2004 08:41 AM
S4Patrick
Sep 11, 2003 03:17 PM
