VAG-COM Discussion
Checking Fault codes?
Old Feb 22, 2006 | 10:57 AM
groovninja's Avatar
New Member
Default Checking Fault codes?
I know this is a generic question but how do you check for fault codes? I have a 2001 Allroad and the check engine light came on last night. I want to see what is going on before taking it in.
Thanks!
Old Feb 22, 2006 | 11:14 AM
Andy@Ross-Tech's Avatar
Banned
Plug in VAG-COM - > Select -> Engine -> Fault Codes
Old Feb 22, 2006 | 11:33 AM
groovninja's Avatar
New Member
Default Re: Plug in VAG-COM - > Select -> Engine -> Fault Codes
Thanks. Now can someone help to explain the codes that popped up??
4 Faults Found:
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
17887 - Brake Boost Vacuum System: Mechanical Failure
P1479 - 35-10 - - - Intermittent
17535 - Fuel Trim; Bank 1 (Mult): System too Rich
P1127 - 35-10 - - - Intermittent
17537 - Fuel Trim; Bank 2 (Mult): System too Rich
P1129 - 35-10 - - - Intermittent
Old Feb 22, 2006 | 11:40 AM
Bracketracer's Avatar
Default have you done any boost logging?
there could be a large number of reasons for these codes
Old Feb 22, 2006 | 01:12 PM
quickaudi:STFA's Avatar
2nd. Log boost, log O2s, and you've got a brake problem.
Old Feb 22, 2006 | 05:59 PM
groovninja's Avatar
New Member
Default Re: have you done any boost logging?
Never done any... not that I know what that is.
Old Feb 23, 2006 | 03:32 AM
probably best left to the shop then
Old Feb 23, 2006 | 02:15 PM
2nd.
Old Nov 16, 2006 | 09:26 PM
lunamollie's Avatar
Did you figure out what the problem was. I have the EXACT same codes on my 2001 Audi A6 2.7t
Nighty
Jun 15, 2012 08:00 AM
kk's woW12
Dec 7, 2008 06:35 AM
kaynos
4.2 V8 Discussion
Dec 1, 2008 07:13 PM
k04/rs6north
Jul 8, 2006 06:13 AM
