Valentine one question?
Old Dec 14, 2001 | 04:03 PM
Carrot TT's Avatar
New Member
Default Valentine one question?
Where is the best place to mount the valentine one rada in the TT?
Old Dec 14, 2001 | 04:17 PM
VenTTed's Avatar
Default Here is one solution...
<center><img src="http://pictureposter.audiworld.com/462/v1uptop1.jpg"></center><p>I hardwired the unit and ran the power cord up the left column and under the headliner. Wasn't too hard to do.
Old Dec 14, 2001 | 05:29 PM
o2bnme's Avatar
Senior Member
Default It depends on if you have the old or new casing
With the old casing you can hide it behind the rear view mirror. That's what I did
Old Dec 15, 2001 | 11:29 AM
Count Floyd's Avatar
New Member
Default Re: Valentine one question?
My V-1 is mounted on the windshield directly below the rear view mirror, using the suction cups. It's hardwired into the dome light assembly. Works great!
Old Dec 16, 2001 | 04:33 PM
PatMusk's Avatar
New Member
hardwire? to the fusebox, how do you do that? I am stupid with car electronics.
Old Dec 16, 2001 | 08:14 PM
o2bnme's Avatar
Senior Member
Default There's a pretty way and an ugly way. Even I could handle the ugly way
Basically plug into an unused fuse (vary between coupe & roadster). Place the remote unit somewhere in front of the info console... I chose lower left corner.
I can't recall which fuse I used.
Old Dec 17, 2001 | 11:42 AM
PatMusk's Avatar
New Member
I dont have a V1, I have the bel980, can i take the cig-adapt off and plug to fuse box somehow?
Old Dec 17, 2001 | 04:26 PM
o2bnme's Avatar
Senior Member
Default If you were the equivalent of Jeff Bipes, I'd say yes, but since you have to ask I'm not sure
I've ventured to do this stuff before and it worked just fine. Took me awhile to do it though and I probably did a crappy job.
Head down to your local Radio Shack and see if the guy there can help you pick out the right things.
Basically, you need a paddle (thin piece of copper that slips into an open fuse recepticle) attached to a wire, an in-wire fuse, more wire up to the detector. I've probably simplified it or bastardized this... Jeff? help?
Electricity doesn't have to be intimidating as long as you practice on someone else's car. ;-)
 Pouria Savadkouei
 Michael S. Palmer
triplecore
18
Jan 17, 2014 07:19 AM
eldoj
Jun 14, 2007 10:16 AM
boricuaA3
Audi A3 / S3 / RS 3
Apr 19, 2007 04:10 PM
Rick 601
Audi 100 / A6 (C4 Platform)
Nov 25, 2003 10:09 AM
JHC
11
Nov 7, 2000 03:18 PM
