Wheel Spacers
I'm thinking 8mm up front and 15mm in the rear.
How do you determine the right application for these different size wheels?
Remember, the 8mm spacers come in hubcentric and Non-hubcentric. Make sure you get the hubcentric and buy from a reputable supplier (like strat or ecstuning) who knows what you're looking for and can supply the correct length and type bolts. There are two types and your wheels will determine which you need. Ball seat (OEM audi) and conical (used on a lot of wheels). Measure the current bolts used for these wheels and add the MM spacing to get the length needed. Here's some pics of my spacer install. The 25's are a different style and first bolt to the hub, then the wheel bolts to them. Picture above is 15mm set.<ul><li><a href="http://public.fotki.com/ttschwing/spacer_install/">Steve's Spacer Install</a></li></ul>
Do I have this right, guys?
