Can I replace my non-Bose amp for a 225w bose amp in my TTR? Is it that simple? Spkrs are the same?
These speakers are 4 ohms impeadance, and they suck just as easily as other cheap speakers.
The rear speakers, and the sub-woofer in the center console in the rear, are powered by the amp in the rear.
Untill I remove these speakers, I cannot tell you what ohm/impeadance rating they are.
Some would say they are matched to the "Bose" amp. OK, If so, then it is highly possible they are low-ohm speakers, like what has been posted, equivalent to say 1 ohm impeadance.
The difference then is in the speakers in the door.
If you have the base system in the 2000-01 TT, you have 4 ohm speakers in the doors, powered by the head unit.
If you have the "Bose Upgrade" , which include the more powerful amp, and the CD changer, you probably have a different set-up, and the speakers are different, that is, different impeadance.
BTW- This all changes if you have a 2002 TT. The amps are all rated differently. there are 3 combinations of power levels, and who knows what type of speaker combinations.
Front Speakers from my non "Bose Upgrade" TTR
<img src="http://people.mn.mediaone.net/jbipes/jpgs/4ohm.jpg">
<img src="http://people.mn.mediaone.net/jbipes/jpgs/fronts.jpg">
I'd have to tear apart my brother-in-law's Altima (used to be my car) if someone actually wanted to know how it all works.
The Altima started out with an 'upgrade' system. I replaced the headunit and couldn't turn the volume (0-20) past 4 without distorting. We threw in the defeator and tuned it for the system. When done, I had a kick butt system.
I'm not sure if it was Bose or not. I'm pretty sure it wasn't actually, but the logic was the same. Too much juice going to low-ohm speakers needed to be toned down a bit.
So, it can be done. I lucked out... my speakers were pretty good.
Another important factor... space. The Altima barely had enough room for the defeator to fit behind the headunit. I have no idea if the TT would have enough room for such a device.
Might have been an unorthodox method, but it worked pretty well actually.
