Rear and Front Camber Adjustment on FWD 180
Old Jun 24, 2002 | 01:38 AM
NIIK TT's Avatar
New Member
Default Rear and Front Camber Adjustment on FWD 180
I have some 20mm spacers to go on and was wondering if its possible to adjust the camber since after installing the spacers I expect that the camber will be very off and need adjusting.
Also my steering needs aligning since the TT is bearing to one side. Should I get the steering alignment done before or after the spacers install.
thanks
Old Jun 24, 2002 | 02:39 AM
hoTTub's Avatar
Member
Default Spacers have nothing to do with Camber
And there really is no out of the box adjustment of camber on the 180 FWD, you can have the spindles slotted or shimmed but it really is not worth it.
Old Jun 24, 2002 | 04:26 AM
Ron G's Avatar
Default Why isn't it worth it ... I'd kill to get more camber on mine and stay stock
for autocrossing
Old Jun 24, 2002 | 05:06 AM
fredfromny's Avatar
Default FWD rear end is toally non -adjustable.
Shimming is out of the question. You'll lose your stub axel becauseof the tight tolerances involved.
Old Jun 24, 2002 | 07:30 AM
4kq's Avatar
4kq
Member
And those changes would make you ILLEGAL.
snowpunk_AGTT
Feb 5, 2007 07:44 PM
Sully
Oct 24, 2006 09:26 AM
a4tisâ„¢[Bye Turbo]
May 25, 2006 02:48 PM
pyranha
10
Apr 4, 2006 02:21 PM
TTeleven
38
Jan 24, 2002 06:48 AM
