NM+HP with my new airbox
Old Aug 25, 2002 | 09:06 AM
carfanattic's Avatar
New Member
Default NM+HP with my new airbox
<center><img src="http://loevenich.bei.t-online.de/nm+hp.jpg"></center><p>I'am happy with the results. Will get my new exhaust in a week. I hope for some better results than.
Old Aug 25, 2002 | 09:08 AM
Alf Garnett's Avatar
Senior Member
Default Ralph, what airbox???
180 hp tt ?
Old Aug 25, 2002 | 09:46 AM
New Member
Default Re: Ralph, what airbox???
The Ractive airbox from which I posted some pics last week. It seemed that people doesn't like in your country. I like it a lot. The numbers speak for themself. B.T.W., the filter is made of the same stuff than a K&amp;N Filter. So when you oil it with K&amp;N Filter oil there is no problem at all with dust.
Old Aug 25, 2002 | 09:53 AM
Wiz's Avatar
Wiz
Yeah, but there might be a problem with oil particles on MAF
Old Aug 25, 2002 | 10:00 AM
New Member
Default Re: Yeah, but there might be a problem with oil particles on MAF
I drive with K&amp;N Filters for over 8 years now in every car I had. No problem at all. The problem is that some people overoil the filter. When you do it right there is no problem at all.
B.T.W., I forgot to mention that the values in the chart are raw values. I didn't use a correctionfactor on them.
Old Aug 25, 2002 | 11:25 AM
Bluto's Avatar
what does that chart look like when running stock?
Old Aug 25, 2002 | 11:47 AM
EighTT's Avatar
Eighth Member of AudiWorld. God-like, glorious and all-knowing.
25 Year Member
If I'm reading this correctly, color me skeptical.
Old Aug 25, 2002 | 12:27 PM
New Member
Default That's a normal chip in Germany...
..nothing special. Chips in your country make lower boost in the higher rpm's. My chip holds over 1,1bar at 6000 U/m. So, what makes you skeptical.
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 25, 2002 | 12:32 PM
New Member
Default Re: what does that chart look like when running stock?
I don't know what it looks like running stock, cause I've got VAGCom when the car was already chiped. Without the Ractive filter I got about 5hp less in the higher rpm's and about 10NM less in the middle rpm's (3000-4500)
Old Aug 25, 2002 | 01:11 PM
New Member
Default My boost
<center><img src="http://loevenich.bei.t-online.de/boost2508.jpg"></center><p>Here is a chart from my boost data. Chart is also from today.
Bob W.
RS4 (B7 Platform) Discussion
21
Aug 31, 2007 06:59 AM
duplicate147489
Nov 3, 2006 12:15 AM
skydivepickle
May 21, 2004 11:02 AM
wakko
Aug 27, 2003 08:27 PM
Negative459
May 25, 2002 01:27 PM
